Hot Water Tank Cleaning: Tips and Mistakes to Avoid
Most of us take our hot water tanks for granted, in that we often fail to consider that they might need to be cleaned of accumulated deposits. If you have decided to clean your tank, the following tips will give you the information you need.
Tip 1 – Turn off Water Heater
Do not forget to turn off the power to your hot water heater.
Tip 2 – Turn off Cold Water
Avoid allowing cold water to flow into the tank during the cleaning process. Be sure to shut off the cold water intake valve
Tip 3 – Connect a Hose to the Water Heater Drain Valve
Avoid draining water from the water heater onto the floor. When you connect your garden hose to the tank's drain valve, take the end of the hose out of doors and allow drain water to empty there. If you aren't able to drain the water out of doors, drain it into a floor drain or a container you can empty.
Tip 4 – Open Drain Valve
Open your water heater's drain valve completely.
Tip 5 – Close the Cold Water Inlet Pipe
Do not forget to close the cold water intake valve before adding your cleaning solution. Leaving it open will allow fresh water to enter the tank and dilute the cleaner.
Tip 6 – Add the Cleaning Solution
Pour a gallon of acidic tub and tile cleaner into the tank, one cup at a time. Avoid pouring it in too fast. After each cup of cleaner has been added, give the cleaner a few seconds to drain into the tank before adding additional cleaner
Tip 7 – Allow Cleaner Time to Work
Do not drain the tank right away. Give the cleaner 3 to 5 hours to dissolve or neutralize mineral deposits that have accumulated in the tank,
Tip 8 – Test the Water Tank
Pull together the opening of a small plastic bag and very tightly secure the bag around the tank water outlet. If the bag begins filling with escaping carbon dioxide gas from the dissolving minerals, this will tell you the cleaner has not finished working. Do not proceed with the next step until the cleaner has stopped working.
Tip 9 – Allow Heater to Flush
After opening the cold water inlet valve, allow the hot water heater to flush for 10 or 15 minutes.
Tip 10 – Reopen Water Intake Valve
Once the water begins to drain, reopen the water intake valve and allow the tank to refill.
Tip 11 – Check Water
If the water is clean and there are no bubbles, this means the cleaner has stopped working. Then, close the drain valve.
Tip 12 – Turn on Hot Water at your House Taps
Don't forget to turn on all hot water faucets in your home. You will need to do this to release air from the water pipes.
Tip 13 –. Turn on Heater
Once all the air is released from the heater and the pipes, restore the heater power.
Tip 14 – Residual Bubbles
Don't be concerned if you see small amounts of frothy water coming from your faucets for a few days after your tank cleaning. This will be harmless are residual bubbles from the cleaning.
