How can I make window seat cushions for a bay window?
To make new bay window seat cushions, do the following:
First, determine how big you want the seat cushions to be, and then obtain pieces of foam large enough to meet your needs at a local outlet. Next, you have to purchase two types of material: one that will protect the foam, called the batting, and a cover material. There must be enough batting available to ensure it is at least twice as big as you will need it to be. Next, pin the batting and foam with upholstery pins. Then, turn the cover material inside out and pin it. Finally, sew all the seams. Finally, turn the new cover inside out again and insert the seat cushion, adjusting it and finishing off any final seams.
