Login Error
Close
How Different is Outdoor Recessed Lighting from Interior?
by DoItYourself Staff
Outdoor recessed lighting is not much different from indoor recessed lighting. The difference between the two types lies in how the housing for the lights are constructed in order to accommodate the different conditions under which the lights work. Outdoor recessed lighting will use more durable material that is waterproof and able to withstand extremes in temperature, as well as the build up of moisture inside the light brought on by rain or snow. Indoor recessed lighting does not have to be built to withstand these weather conditions. Aside from this, outdoor recessed lighting is the same as indoor recessed lighting.
Installing the Proper Recessed Lighting
This does not mean, however, that you can install a lighting assembly that is designed for the interior of your home outdoors. The outdoor recessed lighting assembly is designed specifically to meet the climate and weather conditions it faces. Indoor recessed lighting is not so designed, and may result in the lighting not working properly, if at all.
Uses for Outdoor Recessed Lighting
A homeowner or builder may decide to include recessed lighting in their construction or building plans as a way to provide an accent to the home. Outdoor recessed lighting can serve as a way to increase the aesthetic value of the home, while also providing an element of safety. Outdoor recessed lighting can be energy efficient as well. This is done by using solar powered battery cells within the outdoor recessed lighting that stores energy for use by the lights when it becomes dark. This type of lighting helps the homeowner save on the cost of electricity or other fuel sources that may need to be used in order to power the recessed lights.
What Indoor Recessed Lighting Does
Indoor recessed lighting, on the other hand, is typically wired into the home's electrical circuit and operated by a switch as opposed to storing energy for activation later. Indoor recessed lighting functions to provide more space within a room by moving the lighting sources into the ceiling of a room. The recessed nature of interior recessed lights eliminates the need for shades and light covers. This also cuts down on the amount of dust and other particles that form on the lighting, and reduces the need for cleaning and maintenance.
Finding Ideas for Indoor and Outdoor Recessed Lighting
If you are considering recessed lighting options for your home, both for the interior and exterior, you should visit a lighting showroom. There you can see what distinguishes these two types of lighting from each other, as well as garner ideas on how to best install recessed lighting outdoors and indoors. The lighting showroom can help you plan the inclusion of recessed lighting and give you a cost estimate associated with adding it.
There are many possibilities that you can explore through the inclusion of indoor and outdoor recessed lighting.
 forum activity
