Login Error
Close
How do I add lifts to my homemade hot tub cover?
by DoItYourself Staff
Hot tub cover lifts will aid you in lifting a cover on your hot tub. These are especially useful if you have a wooden cover or a heavy foam and vinyl cover. They are easy to add to an existing cover.
  • Hot tub cover lifts are arms that swing the cover off the tub and up. They should be bolted into the frame of the cover on each side.
  • Hot tub cover lifts can also be added to a roll type cover by installing them on each side of the roller. Roll the cover up, then use the arms to lift it out of the way.
 forum activity
