Login Error
Close
How do I finish concrete block walls?
by DoItYourself Staff
There are 3 common ways to finish your concrete block walls. The first and easiest method is to paint your walls. Be sure you use a primer and a paint that are rated for use on concrete. Standard drywall or wood paint will not be able to withstand the conditions created by a concrete block wall. Your second option is to apply a decorative stucco surface to your wall. You can purchase a stucco wall kit and just follow the instructions for application. The final way to finish your concrete block walls is to use industrial adhesive to glue wood strips to the wall and cover the basement in drywall.
 forum activity
