How do I properly use a wallpaper stripper to remove a wallpaper border?
Wallpaper stripper is one of the methods used to remove wallpaper borders. Getting rid of a wallpaper border using a stripper is very tedious, but with the correct materials, it can be done right. First of all, you must know the wallpaper type you have--strippable or non-strippable. If it’s strippable, the job isn’t too big, start working from the wall corner. The tools needed are a painter’s spatula, paint roller, hot water, wide knife, sharp knife, and chemical wallpaper remover. However, if it is non-strippable, a lot of work is a head of you. Do not use the chemicals, but a wallpaper steamer to moisten the border, then a scraper to remove it.
