Login Error
Close
How Does Fish Emulsion Effect Plant Growth?
by DoItYourself Staff
Fish emulsion can improve the growth of your sprouts and plants by providing them with the essential nutrients to promote healthy leaves and roots.
Germination
When you are germinating seeds into sprouts and you use fish emulsion, you give your seeds the chance to absorb crucial nutrients at the beginning of their adolescent lives. Nitrogen is released slowly into the topsoil or peat, giving the plants the strengthening nutrients necessary to develop hardy stalks and leaves, plus an abundance of chlorophyll—the substance that allows for photosynthesis. (Photosynthesis is the process through which plants use light to create food.)
Chlorophyll is green, and the darker the green in your leaves, the better the plant can create food. As the nutrients feed the sprouts or saplings, the baby plants are given a head start that gives the plant to mature into a resilient, fully-grown plant. Just as healthy beginnings are imperitive for the maturing of children, the first stages of plant life must also be meticulously cultivated.
Adolescence
Using the emulsion as a vegetable fertilizer or a crop fertilizer will protect the leaves, stems, buds and fruits from the scorching properties of the sun, as well as hold nutrients in the soil and on the surfaces of the plant. From both of these points, the plant can absorb fish emulsion’s supplements at its own pace. How much you should give it and which emulsion you should use can vary from plant to plant, so keep in mind the directions for your plant. Just as in germination and sprouting of seeds, the slowly released nutrients encourage the production of lots of chlorophyll. This in turn gives your vegetation to create the food it needs organically.
Maturity
As a fully-grown plant, the nutrients provided by fish emulsion are an important part in maintaining a consistent growth pattern. Many trees and shrubs continue to grow even after reaching the point of maturity. Just as the slow release of nutrients and minerals is important during germination and adolescence, it is also crucial to larger plants. While many trees and shrubs have few problems after maturity keeping strong and making food for themselves, the use of fish emulsion fertilizers is a great way to continue to enhance the beauty and hardiness of a fully developed plant. The bloom count can number higher and the fullness of the plant can be visibly maximized. When used on fruit-bearing vegetation, the fruits can be fuller, plumper, and jucier, not to mention full of the vitamins and nutrients that went into the plants through the fertilization process. These things can also yield you a greater number of edibles from your plants.
 forum activity
