Login Error
Close
How Effective is a Car Ionic Air Purifier?
by DoItYourself Staff
If you are considering putting an ionic air purifier in your car, you are probably wondering how effective it will be, and whether it will be safe to use. The truth is that you should investigate your options carefully before choosing any ionic air purifier, whether you will use it at home, at the office, or in your vehicle.
Ionic Filter Limitations
An ionic air purifier does not actually filter the air. Yes, the air that passes through the purifier must go through a filter first, but the idea of an ionic purifier is that only a small percentage of the air in the area will actually go through the purifier. Ionic purifiers work directly in the air, attaching negative and positively charged particles together and causing them to literally fall out of the air.
Ionic Filter Dangers
There are certain dangers that are associated with an ionic purifier. Namely, the machine produces ozone, and ozone has been proven to cause lung irritation. Both the EPA and the American Lung Association have issed statements that ionic air purifiers may not be as effective as they are depicted to be, and add health concerns due to the ozone they produce.
 forum activity
