Login Error
Close
How High Should a Mantel Shelf Be above a Fireplace?
by DoItYourself Staff
The fireplace mantel shelf is one of the most important elements in integrating a fireplace into a room's decor. It ties the fireplace into the rest of the room while also being able to stand on its own as a decorative statement, all without "sticking out" or seeming out of place. However, in order to fully reap the benefits of a fireplace mental shelf, it is important that you properly place it.
Safety
For safety reasons, any mantel shelves must be placed properly. If your shelf projects 1 1/2 inches or less, there must be at least six inches between the top of the fireplace and the mantel. Any parts of the mantel that project more than 1 1/2 inches must be at least 12 inches from the top of the fireplace. Of course, these guidelines are subject to change based on several factors. Fire safety codes in your area will be the most important determination, but you should also take into account the material your mantel shelf will be made of. For example, a wooden mantel would have to be placed farther away from the opening of the fireplace than a stone mantel. If you plan to store flammable objects on your mantel, you may wish to place it farther away from the opening of the fireplace than required by fire safety code.
Aesthetic
Although safety is the most important thing to take into account when beginning any home improvement project, you should also keep in mind how you want your room to look. Take into account factors such as ceiling height, room decor, and fireplace size, as well as the factors mentioned above. For example, if your ceiling is very high, a mantel shelf placed only as high up as fire safety code requires may appear awkward and cramped. Considering your room as a whole will ensure that your fireplace mantel shelf is a safe and attractive addition to your home.
 forum activity
