Login Error
Close
How Long Does Carpet Padding Last?
by DoItYourself Staff
Choosing the proper carpet padding can make a huge difference in the way that your carpet holds up to wear and tear. Many people know very little about carpet padding or how long it is supposed to last. Here are the basics of what you can expect from carpet pad.
Rebond
The most popular form of carpet pad in the world is rebond. This is recycled pieces of foam that is bonded together with an adhesive and covered by a mesh. It is the most common type of pad because it is the least expensive. It comes in several different densities and can vary greatly in its lifespan. You should expect to get anywhere from a year to 10 years out of this type of pad. The more traffic that you have in the area, the lower the lifespan will be.
Rubber
Rubber padding is another type of carpet pad that has been around for years. It is not as popular as it once was but it works very well and stands up to wear and tear. With a good rubber pad, you could expect it to last 10 to 20 years.
Urethane
Urethane carpet pad is currently the best pad on the market. It provides you with a soft and durable floor. Under normal circumstances, you could expect a urethane pad to last 15 to 25 years.
 forum activity
