Login Error
Close
How Much Does it Cost to Build In-ground Pool Systems?
by DoItYourself Staff
what you'll need
  • Tape measure
  • Calculator
  • Pen or pencil
  • Paper
  • Samples of material
If you are considering buying or installing a pool, you may be wondering how much it would cost to build in-ground pool features into your home. The in-ground pool system is not one which should be dismissed lightly, as you can use it for many seasons of the year, and yet it is perhaps one of the cheapest options, rather than installing a sauna or a spa. If you choose to build an in-ground pool system, then you will need to do a lot of calculations. Rather than rely upon someone else to make those assessments for you, with a little bit of guidance you should be able to follow these rules without too much trouble.
Step 1 - Work Out the Space
Figure out how much space your new in-ground pool will need, both in length and width, and the depth to which it will sink. You may need to look at local town plans in order to assess where gas mains, water pipes, and other utility items are located, as this can seriously limit where you can put your pool. If you have found a suitable area in your garden, or even under your house, for the pool, take a note of these measurements, as they will feature on the calculations.
Step 2 - Work Out the Materials
Decide what kinds of materials you wish to use in your pool. Most designers will offer a supply of sample materials, which you can use to consider. These samples can have the cost per square foot of the material, and any other features which comes with the fabric. Sometimes buying the cheapest option is not wise, and you may not be able to afford the very best, so try for something in the middle.
Step 3 - Work Out Other Costs
There will be a number of other costs included in your pool, including laying the pipes, digging the ground, and fitting the pool into the space. Labor and plumbing costs should not be underestimated, as they can sometimes double the original cost of the pool. You will need to work out the very least you can afford to spend on hiring others to fit the pool, and also how much you can do yourself.
Step 4 - Work Out Running Costs
A pool does not stop costing you money once you have installed it. You will still have to pay for the upkeep of the pool, which can include, water charges (it costs a lot to fill a pool), cleaning services, and the running of any motors which you fit to the pool to keep it clean. These costs will have to be paid on a regular basis, and will probably start the moment you have the pool, so include these charges in your calculation.
 forum activity
