Login Error
Close
How Much Will A Garage Conversion Cost?
by DoItYourself Staff
To determine the costs associated with a garage conversion, think about how the space will be used and how the conversion construction will take place.
Contractor versus DIY
Many homeowners want to complete a garage conversion on their own in order to save money. This is a great plan, but even a garage conversion requires obtaining building permits before beginning the work and having each phase of the project inspected and approved before moving to the next stage. If you complete the garage conversion entirely on your own, you can expect to spend between $2,000 to $10,000 or more.
It may beneficial to work with a contractor during the planning stage. A contractor can help you obtain the initial permits and complete the electrical and plumbing work so that it meets building inspector approval. Once these aspects of the project are completed, you can complete the rest of the project on your own and save money this way. Working with a contractor often costs approximately $7,000 to $20,000 depending on the scale and detail of the project.
Updating to Code
In many cases, a residential garage conversion require that you not only obtain building permits, but that the garage area be brought up to current code. This may entail installing fire sprinklers, additional ventilation, insulation and even replacing the parking space that was provided by the garage.
 forum activity
