How Not to Tile a Ceiling: 5 Common Mistakes
Though you can definitely tile a ceiling on your own, it is a project that requires planning, research and patience. There are several things you can avoid doing that would prolong the project and create costly mistakes.
5 Common Mistakes
- Not planning your ceiling’s layout: You should sketch out your entire ceiling on paper before beginning your project to ensure the measurements are correct and that you have the necessary supplies.
- Not checking codes: Many cities have minimum floor-to-ceiling heights required in basements, as well as requirements for space between lighting fixtures and the old ceiling.
- Creating a sloping ceiling: If measuring the ceiling line from a sloping floor, you end with a sloped ceiling.
- Damaging tiles during installation: Ceiling tiles are fragile and can easily be soiled. They must be handled with care.
- Neglecting electrical work: Planning and completing all electrical work for ceiling lights must be a priority.
