Login Error
Close
How Often Should I Check the Gas Line Attached to a Natural Gas Fireplace?
by DoItYourself Staff
When you have a natural gas fireplace, you need to periodically make sure that the gas line is functioning as it should. The gas line will generally work fine as long as it has been correctly installed. Every time that you turn off the fireplace, you need to check to make sure that the gas line is not leaking. If there is a large leak, you should be able to hear the gas hissing around the fireplace. Make sure that you completely turn the line off when you are done. A gas leak can be very dangerous.
 forum activity
