Login Error
Close
How often should I clean my vinyl fence?
by DoItYourself Staff
Your vinyl fence requires a good hosing once a year with a good high-pressure hose and warm water, if possible. If not, then cold water will suffice. If you encounter stubborn dirt and grime, you can try using a very mild soap mixture that is friendly to the environment. You will find that some bug stains (pitch pine beetles and the like) and certain types of saps are tough to remove. However, a high-pressure hosing should do the trick. If you have a harsh winter with a lot of snow, then an extra early spring washing is a good idea.
 forum activity
