How Often to Do Air Conditioner Maintenance
Air conditioner maintenance is something many people don't think about. However, it is an important part of the overall maintenance of your home. No matter whether it is a window type air conditioner, or a central air conditioner, air conditioner maintenance should be something you do regularly.
Twice A Year Cleaning
Your air conditioner, when maintained, will last for a long time. Regular maintenance will also prevent costly repairs. Set up a schedule of cleaning, and maintaining your air conditioner at least twice a year. You should clean off the coils, the housing, the vents, and the duct work for central air before and after the season.
Keep Covered When Storing
When using a window style air conditioner, cover the actual condensing unit before storing it away. This will prevent any small rodents or bugs from making a home it in. You can also keep a lot of the dust out of the ducts and vents.
Clean Once A Week
While you are in the middle of the summer months, you should also make it a point to dust and make sure the vents are clean in your air conditioner.
Schedule It In
One way to make sure that you keep the air conditioner maintained is to set up a schedule. A simple card located on the side of the air conditioner will keep you on track. Just initial it every time you clean it, or change a filter, with the date.
