How to Add a Sunroom to Your Home
Adding a sunroom to a house will improve your living space while also adding value to your home. Design your sunroom to maximize your home's exposure to the sun without letting in too many harmful rays. The following will provide you a few tips for adding a sunroom to your home.
Step 1– Measurements
Measure the garden to identify what space is available and how big the sunroom can be. If there isn’t sufficient space to construct a sunroom, consider building a gazeebo in your back yard instead. A gazebo is not connected to the house but it will still help you enjoy your garden.
Step 2– Planning
Some sunroom additions will require a building permit. Consult the zoning office and state that the building permit is required for a sunroom because most zoning offices will separate large constructions from smaller ones. This means that you could get the building permit quicker.
Create a design of how the finished sunroom will look. This should include the number and size of windows. The design should also indicate the type of windows and whether they have sliding doors. Plan how you intend to use the internal space. Will it serve as an additional family room, or a place to enjoy panoramic views of the garden?
A detailed plan will help a contractor carry out their work effectively and efficiently. You can hire a specialist to make the design, or do it yourself.
Step 3– Contractors
You will need to hire a professional to build your sunroom, so compare several quotes from local contractors. Check the references of your prospective contractors as well as their licenses and insurance details. Once you select your builder, meet with them face-to-face to set up a work schedule and plan.
Step 4 – Buying the sunroom
It is possible to purchase sunroom kits from garden centers, but they tend to be mass produced and not personalized. Some architectural firms will supply all the goods required to build the sunroom. If this is not the case, you will need to shop for the required windows and additional doors. Choose windows that will let in plenty of sunlight, but make sure that the sizes are correct and in line with the measurements from the design.
Step 5– Electrics
The contractor should be able to build the sunroom in line with the specified requirements of the design with ease. If you intend to make the room an addional family room, you will need to make sure it has the right electrical fittings for lighting and other related equipment. You will need to find a qualified electrician, but once you take care of the lights, your sunroom will be ready for the family to enjoy.
