How to Add Thin Brick to a Stucco Wall
what you'll need
- Thin brick
- Saw
- Epoxy adhesive
- Putty knife
- Wire brush
- Level
Installing thin brick over stucco can provide you with a look that is very similar to what you could expect if you originally had brick siding. Here are the basics of how to add thin brick to a stucco wall.
Step 1 - Prepare the Surface
If you have a smooth stucco surface, you will first need to rough it up a bit so the thin brick will adhere to the wall. You can use a wire brush to rough up the surface. If your stucco is already textured, you will not have to worry about this step.
Step 2 - Apply Adhesive
Nexto apply the epoxy adhesive to the back of your thin brick. Once it is on the brick, you may want to spread it out a bit with your putty knife. Make sure that the entire back of the brick is covered with adhesive.
Step 3 - Apply the Brick
Stick the brick in place on the side of the stucco. Use your level to make sure that each piece is straight.
Step 4 - Cutting
When you get to the edge, you will need to make a cut. Use your saw to cut through the brick, and then place the cut piece on the wall.
