Login Error
Close
How To Adjust Freezers
by DoItYourself Staff
Keeping items in your freezer the right temperature will eliminate spoilage. Spoiled or freezer burned food costs you money. Keeping meats frozen at a low temperature will increase it’s shelf life. Ice cream just needs to be kept at a lower temperature to avoid melting. Having your freezer at the correct settings will prevent ice build up that can limit the space you have. Every freezer model is different. After you’ve checked with your owners manual you can do a few things to adjust the temperature of your freezer.
Temperature Knobs
Most freezer models will have a temperature knob towards the front or side of the unit. These controls have a temperature range measured in numbers from 0 to 10. A 3 is a pretty standard general temperature for a freezer. If you have more meats that need to stay frozen you may want to set it a little colder. If a freezer gets a lot of use you may want to set the temperature cold higher. This will keep the frozen items frozen even if the door is opened often. A freezer that is stuffed with items won’t need to be set as high, since each item will act like an icepack to keep the others items cooler.
Importance of Thermometers
An indoor/outdoor thermometer is fairly inexpensive and will give you more control over the temperature of the freezer. Sometimes it’s hard to know where to set the controls at if you don’t have a clear read of the actual temperature. These thermometers can just be placed in a freezer door. Some models are just strips that stick to the sides of the freezer. Whichever model you choose you will be saving money in the long run. You will know exactly what the temperature of your freezer is, eliminating the need to throw away spoiled or freezer burned food, as well as allowing you to keep the temperature set at the right place and avoid excess energy use.
Use Digital Read-Outs
It might be easier if you use a thermometer with a digital reading. You can put the sensor inside the refrigerator and keep the display unit somewhere out in the kitchen where you can see it. That way you can be certain of the temperature at all times.
Check Recommended Settings
It is up to individual tastes and needs. But generally most people want to prevent bacteria from growing inside their food. But they don't want their electricity bill to skyrocket either. A general rule of thumb is that a refrigerator should be kept at around 34 to 40 degrees F. You probably want to keep your freezer somewhere around zero degrees F. Bacteria generally can't grow in below-zero temperatures.
 forum activity
