Login Error
Close
How to Adjust the Ballcock in a Toilet
by DoItYourself Staff
what you'll need
  • Screwdriver
  • Towel
  • Petroleum jelly
Major plumbing problems have to be addressed by professionals but there are minor troubles, like adjusting a ballcock, which can be done by the homeowner. If you have ever flushed the toilet and the water continued to run, then you have a problem with the height of the ballcock assembly in the tank. There are two issues that can cause the water to continue to run. The first is that the water is too high, so the float ball does not properly close the valve and water enters the overflow tube. The second issue is that the float ball is broken, which lets water in and subsequently it will not properly close the valve. Here's how to adjust the ballcock so that running toilets may never be a problem in the future.
Step 1: Being Prepared
In order to work with the toilet, and specifically the ballcock, you need to turn the water off. Look behind the tank of the toilet. You will see a shutoff valve to just that individual toilet. The valve should be near the floor and is usually found on the left side of the toilet. Turn the valve clockwise in order to turn the water off.
Remove the cover to the toilet tank. You will see a few simple things like a float ball, lever and gaskets. Do not concern yourself with these things yet, as for now you need to empty the tank. In order to do this all you have to do is push down on the flusher. The water will exit through the gasket at the bottom of the tank and not refill, because you turned the water off.
Step 2: Locate the Ballcock
Now that the tank is empty you can begin to identify the pieces inside the tank. You will see the float ball that is attached to a metal or plastic rod. These two things are attached to another lever, which is attached to the flush lever. When you flush the toilet the lever lifts and the float ball rises. When this happens a chain is pulled, which pulls up a diaphragm that is covering the hole to the pipe. For this easy fix, you should only concern yourself with the thumb screws near the top of the assembly. They may also be screws or wing nuts.
Step 3: Adjusting the Ballcock
The moisture in the tank can cause issues with adjusting the ballcock. Dry the assembly with the towel and then grease the screw area with a small amount of the petroleum jelly. This will help to lubricate the screw so that it can be easily moved. In order to lower the ball further to close off the pipe, turn the screw clockwise by half turns. This will drop the float ball more precisely than bending the lever.
 forum activity
