Login Error
Close
How to Apply Ceramic Floor Tile Adhesive
by DoItYourself Staff
what you'll need
  • Ceramic floor tiles
  • Measuring jug or gage
  • Powdered/liquid adhesive
  • Tile trowel with teeth
  • Mixing bowl or bucket
When installing your own ceramic tiles, it is very important that you know how to apply ceramic floor tile adhesive, as a mistake can lead to an uneven and bumpy floor. This article will explain how to apply ceramic floor tile adhesive to help you in installing your own ceramic floor perfectly. Follow these directions carefully when preparing your ceramic floor tile adhesive.
Step 1 – Consultation
When you purchase your tiles, ask the dealer or assistant about the types of ceramic floor tile adhesive that they recommend. There are various types of adhesive that should be used on different tiles. The assistant will have knowledge of the different types of adhesive and will be able to give you guidance. Additionally, you could search online for this information.
Step 2 – Calculations
Use the instructions provided with your tile adhesive to identify the quantity that you need.
Step 3 – Mixing
Do not mix too much tile adhesive at once. If you make your tile adhesive in smaller amounts, you will be able to mix it better, ensuring it is the correct consistency to lay your tiles.
Step 4 – Applying
Use the adhesive as soon as it is ready. To apply it to the floor, you will need a tile trowel. Place some of the mixture onto the trowel and run it across the floor in straight lines. Ensure that you use the same amount of pressure when dragging the tile trowel so that the mixture stays level. If the mixture is not level, when you lay your tiles, they will not be even. This will leave you with an uneven floor. Apply additional adhesive to ensure that there is an ample amount to lay the tile.
Step 5 – Creating Ridges
When you have completed the line of adhesive application, you need to create ridges in the adhesive. Locate the teeth on your tile trowel. Drag the teeth through the adhesive on the floor. Again, ensure that you apply the same amount of pressure along the entire line so that the ridges are even. You should drag the teeth in the same direction as you did when you applied the adhesive. Remember to keep your ridges as straight as possible.
Step 6 – Applying the Tiles
When you have finished creating the ridges, it is time to lay your first tile. To lay your tile, you must push it into the corner of the area in which you have applied adhesive. Push the tile against the floor by pressing very firmly. Ensure that the tile is as tightly pressed to the wall as possible.
If you follow these steps, you will be able to lay your tiles as a professional would. The most important aspect is the way in which the ceramic floor tile adhesive is applied. Once you have mastered this, you will have no problem with your tile application.
 forum activity
