How to Apply Stucco Siding
If you live on the West coast or in the Southwest, then you are probably familiar with stucco siding. Stucco siding is a highly durable inexpensive form of residential and building siding that is very popular in areas that are heavily influenced by Spanish or Mexican building styles.
Procedure
Step 1 – Preparation
Examine the wall you will be stuccoing. If you will be applying stucco siding to an already existing concrete, brick or other type of siding, you need to completely clean the walls of dust, dirt and debris.
You will also need to seal any cracks or breaks in the wall that might allow water seepage which will damage the interior of your walls. You can use caulk to repair any damage or breaks.
Step 2 – Apply Binding Compound
If you are applying stucco to cinderblock or concrete walls, you will need to apply a binding compound and let it dry so that the stucco will adhere to the wall. If you are applying the stucco to a wood wall, you will need to place roofing felt on the wall along with chicken wire or metal netting.
Step 3 – Mix Stucco
Mix one part Portland cement with one part masonry cement and eight parts clean, damp medium sand. You will be using this mixture for both the scratch coat and the top coat of stucco.
Step 4 – Apply Scratch Coat
Next you will need to apply the first layer or scratch coat to the wall. Apply approximately 1/4 to 1/2 of stucco to the wall. Let the stucco harden slightly and then use a rake to cut horizontal lines into the stucco about 1/8 inch deep. Stucco does not do well when it is applied on extremely hot days or when it is very windy and will dry out too quickly. This is a siding application that needs to dry evenly and not be allowed to completely dry out before the second top layer is applied.
Let this layer cure for approximately 36 to 48 hours, spraying lightly with water occasionally to prevent it from completely drying out and so that the second layer will adhere correctly.
If you have not yet practiced applying stucco, start with a back wall that is not facing the street so that your final walls will be those in which you have had enough practice applying the stucco to become proficient and you will have the best application.
Step 5 – Apply Second Coat
Add the top layer of stucco. This is the layer that should have color in it if you are going to color the stucco. This layer should be applied so that it is approximately 1/4 to 1/2 inch thick.
Step 6 – Apply Texture
Once you have the stucco applied, use a trowel to create a texture into the siding. This texture can be as light or as heavy as desired. As you work, try several different trowel styles until you settle on one that is pleasing.
Step 7 – Cure
Let the final coat cure for 36 to 48 hours.
Let the top coat of stucco cure for 6 to 8 weeks before painting.
