Login Error
Close
How to Attach a Hole Saw to a Drill
by DoItYourself Staff
what you'll need
  • Hole Saw
  • Pilot Drill
  • Drill
A hole saw is a very important tool that can cut holes in drywall, wood, fiberglass, plastic and other thin material. This device cannot do anything on its own because it relies on the rotational power of a drill in order to work. Since drills are very essential to the overall function of the hole saw, it is wise to choose a drill that can provide enough power for the a hole-cutting task. Follow the simple steps below to effectively attach a hole saw to a drill.
Step 1 – Choose a Powerful Drill
It is recommended that a drill with at least 14 volts of power is used for this specific task. Increase the power to 18 volts when using a cordless drill. A powerful drill allows the hole saw to cut consistently and neatly on a piece of material. This ensures that every cut made is of top quality.
Step 2 – Connect the Pilot Drill to the Chuck Arbor
Hole saw packages usually have a pilot drill that connects the hole saw to the drill itself. Since the hole saw needs to be connected to the drill securely, the pilot drill provides a sort of an anchor. It fits the hole saw perfectly on one end and the chuck arbor on the drill on the other end. Connect the pilot drill firmly on the chuck arbor and make sure it is attached tightly in place.
Step 3 – Attach the Hole Saw to the Pilot Drill
Hole saws come in a variety of sizes: 1 inch, 2 inches, 4 inches, etc. Choose a hole saw with the correct diameter needed for a hole-cutting project. These tools can be purchased at any hardware supply shop. Notice that the hole saw has a bit that can be attached to the pilot drill. Attach the hole saw bit to the pilot drill through the threads in the chuck  arbor.  Secure the two together by screwing them tightly. A loose attachment is a risk that needs to be avoided. Use a screwdriver to make sure the screws are firmly in place.
Step 4 – Lock the Hole Saw
After carefully securing the saw to the pilot drill and the arbor, lock it using the mechanism it features. Some hole saws use a pull back motion that clicks the tool and locks it in place. Simply push the hole saw drill’s active head and that’s it. Other hole saws use a latch mechanism. The active head on the saw can be simply latched into the notches of a drill. As soon as it is locked, it is now ready for use.
When attaching a hole saw to a drill, always ensure that the device is not connected to a power source. The saw can easily cut through any material including flesh. As much as possible, wear protective gloves and safety goggles when working with these devices.
 forum activity
