Login Error
Close
How to Avoid Common Mistakes in Lawn Care
by DoItYourself Staff
Even though you are keeping up with lawn care you're frustrated because it just doesn't have that healthy full look you were expecting. It may just simply be a result of not knowing these common lawn care mistakes.
Mistake 1 - Dull Lawn Mower Blades
When blades are dull, they don't cut the grass, they rip it. This causes "cut injury" which makes it difficult for the lawn to water absorb water. Making your lawn weak and more susceptible to disease and damage.
To determine if your lawn mower blade needs to be sharpened just take a look at your grass from the ground up. Kneel down, put your face close to the ground and look horizontally across the yard. If you see shabby and shredded grass blade tips rather than a nice clean crisp cut, it's time to sharpen that blade.
Mistake 2 - Cutting Grass Too Short
This is another way to weaken a lawn's over all health and could cause browning or wilting. Allow your grass to grow up to 3" to 3 1/2" in height then cut only 1/3 off the top. This length encourages bounce and allows for less shock and a better ability to absorb water and nutrients. Adjust the height of your mower blades by raising or lowering the wheels.
Mistake 3 - Watering Improperly
If you water during a hot day the water will evaporate before the grass receives any benefit.
If you water at night, especially in areas of high humidity, the grass will often mold and mildew since it does not have the advantage of the sun to aid in the process of water absorption.
Over watering can be an issue during the day as well. It is a bit of a science to understand all the environmental factors that influence the health of  grass so, the best way to determine if your yard needs watering is to simply look for these signs:
  • The grass appears to have a blue-gray tint
  • The tips are beginning to curl
  • When you walk on your lawn, the foot prints do not quickly bounce back, the impression remains flat to the ground longer.
Mistake 4 - Improper Fertilizing
Over fertilize and you risk burning the grass or causing it to grow too fast and you will be mowing more than you need to.
Grass type and climate need to be considered before applying fertilizer. Fertilizer should be applied a minimum of 2 times per year with the maximum being 4 to 5 times. Verify with your local lawn care professional to be certain you are applying the right product for your grass type.
Water immediately after, or within 24 hours of applying the fertilizer to your yard. By waiting longer the undissolved pellets will start burning the grass.
Time of year plays an important part in effective fertilizing based on if your grass is a warm season grass or a cool season grass.
Warm Season Grass, grass that "greens up" during the summer months and goes dormant, stops growing while loosing its green color, should be fertilized at least 2 times during the spring and summer months.
Cool Season Grass is a grass that grows nice and green during the spring months, grows slower in the summer and then starts growing again in the fall. It never looses it's green and should be fertilized during these spring and fall growth periods.
 forum activity
