How to Avoid Runs while Spray Painting
what you'll need
- Spray Paint
- Fine Grained Sandpaper
- Sanding Block
- Water
Spray painting is a great way to cover a large area with paint quickly and easily. If you are doing any project like this, spray painting will often be the way to go, as you will save a great deal of time and effort over painting by hand. However, even though applying spray paint is a straightforward process, there are still many things that can go wrong with it. These problems include dripping, sagging, and of course runs. Because of this, it is important to use the correct techniques when using spray paint. What follows should give you enough information to avoid runs, and help you to remove them if they occur.
Step 1 - Apply Spray Paint Correctly
The main thing that causes runs in spray paint is incorrect application. In particular, applying too much spray paint will often cause runs or other problems. Unfortunately, it is easy for an inexperienced person to accidentally apply too much spray paint. This is because it can be difficult to judge exactly how much spray paint has been applied already. Naturally, the solution to this problem is to err on the side of caution. While it is quite difficult to remove paint after it has been applied if there is too much, it is quite easy to add more if it turns out there is an insufficient amount.
When applying spray paint, hold your can approximately 18 inches from the surface you are painting. If at all possible, hold the paint can so it is oriented straight up and down. If not, come as close as possible. Spray the paint evenly, never stopping on one spot. Use even passes to cover the entire surface. Once you have applied a small amount of paint to the entire surface, stop and allow the paint to dry. It is quite likely that you will need to apply a second coat, but you will be practically guaranteed to have an even coat of paint that is free of runs and other problems.
Step 2 - Removing Runs
Unfortunately, it is possible to end up with one or more runs no matter how good you are at spray painting. When this occurs, all is not lost. It is possible to remove runs in spray paint. Obviously, it is better to avoid problems with paint in the first place, as removing them is much more work.
First, soak a sanding block in water overnight. Once you have done this, get out a second sanding block or section of fine grained sandpaper. Start off by sanding the problematic areas to remove extra paint with the wet sanding block.
Step 3 - Fixing the Paint Job
Once you have finished sanding, it is quite likely that you will need to fix up a few areas of your paint job. If this is the case, simply spray paint over the areas that need touching up, being very careful to stop long before paint builds up enough to run. Taking the time to use multiple coats is always a good idea.
