How to Balance the Sound in a Home Stereo Sound System
Proper positioning before adjusting the volume of speakers is necessary to achieve maximum effect in a stereo sound system. Here are some tips on how to balance the sound in a home stereo sound system.
Step 1 - Position the speakers
The left and right front channel speakers must be positioned at a 45-degree angle and about 28 inches away from the listener. For the rear speakers, position it at least 56 inches from the back of the listener.
Position the center channel in the middle so that it is facing the listener directly. The subwoofer may be placed either in the front or in the back.
Step 2 - Adjust the Sound Volume
Adjust the volume of the front speakers first. Some home theater systems have different volume adjustment for each of the channels. Start by adjusting the front speakers, then the rear speakers and finally the subwoofer volume.
For surround speakers, adjust the delay for the rear surround, typically set at 15 milliseconds.
Step 3 - Check the Sound
After setting up the proper volume adjustments, test the sound system by playing a movie. Check if the sound is clear and crisp, and if you can feel the sound flows smoothly from one speaker to the next.
Audio balance of a home theater system is a matter of personal preference. Adjust it accordingly to make your movie watching more enjoyable.
