How to Blow Insulation into Existing Walls
what you'll need
- Cellulose blow insulation
- Stud finder
- Hole saw
- Safety goggles
- Protective mask
- Drywall tape
- Insulation blower
- A friend
- Drop cloth
- Pencil
- Rag
- Spackle
- Trowel
Blow insulation is a quick way to add insulation to your home. You can put blow insulation in your walls, attic, crawl space and under the floors. It is a very versatile insulation as far as its ease of installation is concerned. The one problem a homeowner can face is installing blow insulation into existing walls. This is especially a concern with older homes where insulation was more of a luxury than a necessity. The following article will show you how to install blow insulation into existing walls without removing drywall blowing cellulose fibers between the studs.
Step 1 - Creating Access
Staring down a sealed wall and needing to add blow insulation to it can seem like an impossible task, and even more impossible because of the mess you could make doing this yourself. It is actually not that hard to do and there does not have to be too much mess involved. Place your drop cloth tight against the wall where you will be working. This will catch excess blow insulation and dust from the drywall. Use a stud finder and make a mark at each stud. Cut a 2-inch diameter hole in the drywall with the hole saw and carefully remove it. You will use it again later. Try to place the holes close to the top of the wall. This allows the blow insulation to fall naturally, settle and pile.
Step 2 - Installing Blow Insulation
You will need a friend to help with this part of the project. Place the head of the blow insulation hose into the hole and continue to let it drop towards the bottom. Wrap and hold a rag around the blow insulation hose where it touches the wall. Have your friend turn the blower on. As the cavity fills pull the blow insulation out of the hole. Go slow to ensure the cavity gets packed tight. As soon as you feel resistance near the top of the cavity have your friend turn the insulation blower off. Carefully remove the hose and repeat with every hole you made. It is very important to work methodically and carefully. Always use protective glasses, gloves and a protective mask.
Step 3 - Sealing the Holes
You have just filled your walls with blow insulation, but now you have a bunch of holes in the drywall. You cannot leave it like this, so it has to be patched up. Saving the drywall discs you cut in Step 1 is what allows you to make this an easier job than it seems. Try to keep the discs in order of cutting because if you made a slip of any kind the piece may not fit in other portions of the wall. Carefully slide a disc into the hole you cut. Have your friend hold the disc in place as the blow insulation may push against it. Apply drywall tape to secure it and then finish the job with Spackle.
