How To Brace Your Unestablished Palm Tree
what you'll need
- Burlap
- Wooden Posts
- 2x4 Stakes
- Nails
- Rope
- Hammer
A palm tree is a unique and popular plant that graces many landscapes in tropical regions. Many species of these trees can grow to 20 to 40 feet tall and require certain growing requirements. They are especially popular around coastal areas as they are resistant to wind and offer a special ambiance.
When growing palm trees, you must make sure that they take hold and establish themselves in the area you planted them. You may also need to use heavy equipment to make room for the root ball if you are planting a mature tree. Every palm tree needs bracing while it is establishing its foothold.
Step One - Plant Palm Tree
Planting the palm tree is a rather extensive project. You need to dig a large hole for the root ball. In fact, if it recommended to overexcavate the hole by 30 percent to make sure the soil is loose around the root ball. Lift the tree and place it as vertical as possible in the hole. Many species of palm trees have bends in the trunks, so getting them perfectly plumb will be impossible.
When you plant a palm tree, the soil will usually be loose and sandy. While this is good for the tree itself, the root system does not have room to spread out and grow deep. This makes it unsteady while it is establishing itself. Once established, the tree will withstand hurricane force winds—but before that, a slight breeze can topple it.
Step Two - Wrap In Burlap
Wrap the trunk of the tree with 16-inch wide strips of burlap. This heavy material will help to protect the tree from any of the wood braces. As the tree shifts and grows, the piece of wood can dig into the trunk system, causing wounds. The burlap will keep that from happening. Wrap at least 2 layers of the burlap about ¼ of the way up the trunk and tie to the tree with rope.
Do not nail, staple or screw the burlap into the tree. The plant will use a lot of its energy and nutrients to establish its root system, and any wounds and gouges can be fatal for the tree.
Step Three - Drive In Stakes
At an equal distance around the tree, drive in 2x4 stakes about 5 feet away. These should be at least 3 to 4 feet deep to withstand the pressure coming from the braces.
Step Four - Attach Wooden Posts
Lay posts from the burlap on the tree to the wooden stakes. Nail them to the side of the stakes, but tie them to the trunk of the tree with wire ties. Wrap the wire around the brace and the trunk and tighten.
Step Five - Water And Watch
After you have braced the palm tree securely, water it regularly to help the roots grow and establish in the soil. Once you see that the tree is no longer shifting, you can remove the braces one at a time.
