How to Build a Corner Shower Shelf
what you'll need
- Scissors
- Measuring Tape
- Cardboard
- Tile
- Tile Saw
- Grout
A corner shower shelf in your bathroom can not only look elegant but also prove to be extremely useful. Although numerous shower shelves can be bought, building one on your own allows you to customize it to suit your needs. Shelves can vary in shapes, sizes and types, and building one on your own will allow you to match it to the aesthetics of your bathroom.
Step1 : Choose a Suitable Tile
To make your shelf look elegant, it is recommended that you choose a tile that suits the overall theme of your bathroom. You can look at different designs to invoke your creativity, but the main objective of the tile should be to complement the rest of the bathroom.
Step 2: Determine Size and Shape of the Shelf
After selecting the tile, you should identify the exact corner of the shower where it would be most suitable to install the shelf. You should take measurements of the space available so that you do not end up making an oversized shelf that leaves your bathroom looking crowded. In addition, personal needs should be kept in mind, and the size of the shelf should be decided with respect to the number of essentials that you may potentially place on it.
Step 3: Cut out a Cardboard Template
After deciding on the shape of the shelf, draw it out on cardboard and cut it to make a template that will serve as a benchmark when working with the tile. Shelves may have to be adjusted against curvy walls or abrupt corners. This template will aid in accommodating all these factors.
Step 4: Cut the Tile
After ensuring that the template fits in the corner and will accommodate your needs, you can use it to cut the tile. Place the template across the tile and use a tile saw to cut the tile along the template’s boundaries.
Step 5: Install the Tile into the Wall
Use the measurements made earlier to judge the height to which you would like the shelf to be. Make sure that the shelf is neither too high nor too low. An ideal height for a shelf is considered to be slightly below the waistline. After determining the height, use adhesive to stick the shelf to the wall. When installing a shelf in an already tiled bathroom, you can cut the tiles at the desired location to make space for the shelf. However, if tiling the entire bathroom, then you can proceed sequentially from the floor to place tiles. As you reach the desired location of the shelf, use glue to place the shelf and then proceed in a similar manner to tile the rest of the wall.
Step 6: Grout the Shelf and the Tile
Proceeding systematically from tile to tile, you should now grout the wall to cement the shelf firmly in its place. The key to an excellent result lies in this step. With a good grouting job, you may well achieve the results of a professional. Once done, neatly finish off your project by removing excess grout.
