Login Error
Close
How to Build a Four Poster Bed
by DoItYourself Staff
what you'll need
  • Measuring tape
  • 3/4-inch thick plywood for the headboard
  • Wood glue
  • Clamps
  • Electric sander
  • 4 x 4 posts at least 6 foot high
  • Lathe duplicator
  • 5 pieces of 1 inch by 8 foot pine board
  • Screws
  • Electric drill
  • Paint or wood stain
  • Paintbrush
  • Measurements of the mattress you plan to use
Building a four poster bed is an incredibly daunting task for the average DIY woodworker - but the satisfaction of building your own four poster bed will far surpass any difficulties you overcame in the process. Deceivingly inexpensive, a DIY four poster bed will inevitably feel infinitely more comfortable than a shop-built equivalent! It will also make a far less significant dent in your wallet! This guide will cover all of the basics of four poster bed construction, though feel free to experiment beyond these instructions.
Step 1 - Mattress Measurements
First of all, measure the length of the mattress that will rest on the finished project. It is a lot easier to do this than find a mattress to fit your custom bed.
Step 2 - Building the Base
Plan the required height of your four posts as it will be very hard to cut these down accurately once you have begun construction. The base will be compiled of 1 inch by 8 foot pine wood beams. Once decided upon the post height, cut down your first beam to the same length as your mattress. Remember to take into account the extra length the depth of the four posts will add on. Drill holes into the posts 10 inches from the floor and screw in your two side beams. Cut down another beam to the specific width required for your bottom beam and screw this in. Sand softly for high quality look.
Step 3 - Constructing the Headboard
Take your pieces of plywood and after cutting them to the correct width for your bed, clamp together after gluing in order to achieve the correct thickness required of your headboard. Depending on the accuracy of your power saw, you may be able to let your creativity run wild here in terms of the final shape of your headboard.
Step 4 - Headboard Cosmetology
If custom wood-cutting is not your strong point, remember that you can try a variety of different headboard designs once the shape is cut. Many will spice up a standard rectangular or rounded headboard with the use of copper tiling or engravings. Use this opportunity to think of an eye-catching centerpiece for your bedroom. Attach this headboard by screwing it in between the two top posts for a flush, professional look.
Step 5 - Introducing Cross Beams
Now that the skeleton of the entire bed is complete, we must build the bed frame's cross beams. You will have ample materials left from your pine wood for this, though if you think you may run out simply buy a few more. Aim to have at least five cross beams to provide enough support for the mattress and bed users. Attach beams downward through the bed's side beams, allowing for a completely clean finish once the mattress is in place. Use a lathe duplicator to create a more antiquated feel.
 forum activity
