Login Error
Close
How to Build a Neo Angle Shower Pan
by DoItYourself Staff
what you'll need
  • Durock
  • Shower base
  • Thinset mortar
  • Clear silicone
  • Deck screws
  • Liquid nails for tub surrounds
  • Masonry drill bits
  • Cordless drill/driver
  • 18" Channel-Lock pliers
  • Jig saw with carbide blade
  • Reciprocating saw
  • Notched flooring trowel
  • 24" level
This neo angle shower pan has three major sections, which includes the base, the glass front, and the shower surround that is glued to its walls. Installing the base is the trickiest of them all, but you can surely do it on your own. All you have to do is to prepare the materials and tools required to keep you going with the shower pan building.
Step 1 – Set Off Shower Pan
Make use of a multi-layered approach in building a neo angle shower pan. Employ a mortar bed and a waterproof membrane. Set off the shower drain, which is the mere place intended for the water to go out. The top half acts similar to a regular drain, while the bottom half offers backup drainage. Place the supporting overhang of the drain precisely on the subfloor. It should be kept in place, along with the mortar that you will install later.
Step 2 – Install Neo Angle Shower Pan
Install first the shower pan lining. Make use of chlorinated polyethylene (CPE) sheet membrane in the shower pan liners, because it bonds with itself in order to create any shower pan dimensions. Put blocking among the studs surrounding the entire pan area perimeter, ensuring that the blocking extends one inch higher than the upturned pan sides. Moreover, ensure that every fastener is flush or countersunk.
Once you are sure that it fits right, eliminate the membrane, loosely twist the membrane clamping bolts to the drain’s lower half and run a rubber sealant surrounding the lower drain lip. Place the membrane above the shower floor then lower it in place. When folding and creasing the excess material, clip it with the wall blocking, holding the entire staples within one inch of the highest edge. You need to apply sealant among the corner folds’ layers to clasp tight the material alongside the wall blocking.
Next, install the prefabricated dam corners. Use two 1/8-inch beads of sealant, which are spaced 1/2 inch apart, with the pan membrane, and then utilize a trowel to place the dam corners with the sealant. With the membrane intact, place and tighten the bolts and cut a hole inside the membrane to unlock the pan towards the drain.
Step 3 – Finish the Installation
Allow the mortar floor to float. Prior to the installation of the mortar bed, loop the adaptable drain screen to the clamping ring drain’s body, and set it at the ended height of the tiled floor.
Now, place pea gravels surrounding the drain’s base to avoid the deck mud from pushing the weep holes. Drift out about half of the entire deck mud then put a part of reinforcing wire. After, you need to wrap the wire with the left over deck mud. You need to use the 13/13-gauge 3x3-inch mesh, or 16/16-gauge 2x2-inch mesh in it. Next, float the neo angle shower pan to its finishing slope.
The mortar bed’s finished height should position 1/16 to 1/8 inch over the floor tile drain’s top, and 1/8 to 1/4 inch underneath the wall tile’s bottom rim. Level the front edge top of the wood float so that the shower pan rides with the wall tile’s bottom edge that you installed. Allow it to dry for 24 hours, and then test it if there is no water leak and the drain is functioning well.
 forum activity
