Login Error
Close
How to Build a Privacy Fence Gate
by DoItYourself Staff
A privacy fence can help ensure the security and privacy of your home. With a privacy fence, you can keep prying eyes, stray animals, and unauthorized individuals away from your property. Privacy fences can be a little costly if you hire professional contractors to do the job. To get more savings and still enjoy the benefits of a privacy fence gate, you can construct the structure yourself. Building a fence gate is easy that even the average DIY person can do it without much trouble.
Tools and Materials Needed:
Construction permits
Measuring tape
String
Nails
Your material of choice for the gates and posts (metal, wood, etc.)
Hammer
Saw
Safety goggles and gloves
Shovel
Step 1 – Secure Building Permits
Secure a permit for the building and construction of a privacy fence gate. Each state and local community have varying laws concerning structures such as boundaries and gates, and you need to be certified that you can build a privacy fence gate with the measurements allowed for where you live. You can inquire about permits from your local municipal hall or the library.
Step 2 – Measure the Area
Measure the area where the fences will go. Mark the area with nails and use the string to mark where the fences will stand. Leave sufficient space for the fence door.
Step 3 – Cut the Materials
Measure the posts and the wood according to how tall you want your fence to be. Remember to follow the guidelines stated on the permits and the specifications allowed on the regulations for construction in your area. Cut the materials according to the measurements you made for its height.
Step 4 – Dig and Bury
Dig a whole on the ground. The hole should be deep enough for the posts to fit into securely without any support. Fit the posts into these holes.
Step 5 – Set up the Rails
Attach planks of wood to the posts. Make sure that the posts are durable and secure enough to hold the planks of wood. The planks will serve as the fence itself and you can add as much planks as you want depending on your needs.
Step 6 – Attach the Fence Panels
Hold up and attach the fence panels to the rails using nails and a hammer. Make sure that each panel is secure and uniformly leveled with the other panels to create a neat, well-made look.
Step 7 – Install the Door
Install the door in the space allotted for it. You can get a pre-made or a custom-made door to fit your fence and attach it yourself. Make sure that the hinges, bolts and handle come with the package. For special types of wood fences, you might need to ask a professional to get the door custom-made.
Building a privacy fence requires little to no carpentry skills and experience at all. You just have to make sure that you are able to get the proper measurements of the posts, rails and panels so that they will perfectly fit together. It is also important that you never forget to use safety equipment when doing the job. Likewise, you should always keep in mind the state and local regulations for construction and property boundaries in your area to avoid discrepancies with neighbors and the local authorities.
 forum activity
