Login Error
Close
How to Build a Recessed Shower Shelf
by DoItYourself Staff
A recessed shower shelf adds to the beauty, elegance, functionality and style of your bathroom. Building a small recessed area in your shower that can store shampoos, bath gel and soap is limited by space. The only available area where recessed shower shelves can be installed is between the framing studs. A comfortable sized recessed shower shelf is around three inches in depth and fourteen inches in width, which is the distance between the wall studs.
Procedure
Accurate Marking
The first step is to locate the wall studs between which you are planning on building your niche shower shelf. Locate the studs with accuracy before proceeding to the next step.
Vertical lines have to be precisely marked next to the studs on the wall where the recessed shelf will go in. Use a level to make sure that the lines you draw are accurate and straight.
On the wall where you want your niche shelf, create a box outline by drawing horizontal lines between the vertical lines.
Cutting Process
A hole has to be drilled in the wall enough to fit your saw inside the marked box. Along the marked horizontal lines, cut through gradually until you reach the area where you encounter the vertical wall stud with the saw. Take care not to cut into the wall stud.
Completely remove exiting wall covering by cutting along the vertical lines.
Framing the Recessed Shower Shelf
To ensure that the boards fit perfectly into the niche, it is necessary to measure between the wall studs accurately. Matching to the wall studs already in place, measure precisely and cut two wall stud board pieces to make them fit into the niche shelf space across the vertical wall studs.
Be sure to test fit the boards to check for accuracy. Note that they fit in snugly but are not too tight.
To the horizontal cut edges, install the two horizontal boards taking care to place the face to the inside of the wall. Secure the boards with the help of 2-inch long wood screws to the existing wall studs.
Finishing the Recessed Shower Shelf
Cover the newly prepared rough frame opening with a concrete backer board measured and cut to perfection. Glue this backer with the help of a tile adhesive. It is important to ensure that the surface is finished in an even manner to facilitate tile installation.
Using a tile adhesive, install the tiles you have chosen on the surface of the backer board. Tile adhesive has to be carefully applied to the back of every single tile.
Completely cover the inside of the recessed shower shelf by cutting tiles with the help of a tile saw to accommodate the edges. Leave it to dry overnight.
The next day, fill the joints between individual tiles with tile grout of your choice. Use a trowel that is covered by sponge for this purpose. Ensure you wipe away excess tile grout immediately. Remove residual tile grout using a wet sponge to give a complete wipe down.
Before starting the entire procedure, be sure to measure the height of your largest shampoo bottles to ensure you accommodate them.
 forum activity
