How To Build A Small Brick Wall
what you'll need
- Bricks (8.5 inches long, 2.5 inches tall and 4.5 inches deep)
- A brick trowel
- Mortar
- Water
- Jointer
- Plywood
- Saw
- Wheelbarrow
A small brick wall can help separate, define, divide or add decoration to any property. Uses include providing privacy or marking property lines. Small brick walls can be used as retaining walls in yards and gardens. Although brick walls are used in may construction projects requiring professional installation, small wall projects are within the reach of many do-it-yourself enthusiasts when following these steps.
Step 1 – Preparation
You need to check with your local municipality to determine what codes, if any, might be applicable along with obtaining any necessary permits. Also, make sure your property does not fall under any restrictions limiting or prohibiting the building of a small brick wall.
Step 2 – The Foundation
Create a level foundation by digging a small trench the length of the wall to be constructed. Form out the base of the trench to make sure it is level as possible. Use a level tool to check it.
Step 3 – Mortar
You need two mortar boards that are two-feet square. Mix the mortar in a wheelbarrow by hand. Make this task easier by mixing the mortar in two separate batches. Put mortar on the mortar boards placing these near where you will be working so they are in easy reach.
Step 4 – Bricks
Place piles of bricks along the line where the wall will be built so you have easier access as the project proceeds.
Step 5 – Using the Mortar
Place a layer of mortar along the base where the wall will go. Work the mortar bed in an up-and-down pattern to allow it to move once bricks are laid on it.
Step 6 – The First Layer
It is important to get the first layer of bricks as level as possible, Keep adjusting each as you place them on the mortar bed using a level to guide your progress. Remember to hold the level vertical to each brick to make sure they are sitting squarely. Use the trowel to remove excess mortar applying this to the top of the brick for the next level.
Step 7 – Keep Going
Repeat steps 4 through six paying attention to leveling and squaring each row as the wall gains each additional level until you arrive at the height you desire.
Small brick walls also can take on shapes other than straight lines, especially when framing flower or plant beds. Furthermore, planters can be incorporated at the top of small brick walls adding another decorative dimension to its construction. Some brick wall builders get creative by constructing double thick walls, combining two lines, sometimes more, to create customized looks.
Brick walls accent coverings for stepped-up landscape designs where the back-end of the wall is embedded into the earthen wall.
