How to Build a Teak Rocking Chair
what you'll need
- Two 1 5/8 x 2 1/4 x 22 1/2 inches teak wood as front posts
- Two 1 5/8 x 11 x 40 inches teak wood as back posts
- One 3/4 x 3 1/2 x 22 inches teak wood
- Two 3/4 x 3 1/2 x 20 inches teak wood
- Two 3/4 x 3 1/2 x 20 inches teak wood as side horizontals
- Two 5/16 x 3 1/2 x 20 inches teak wood as back slats
- Two 1 x 4 1/2 x 25 inches teak wood as arms
- One 2 1/4 x 6 x 33 inches teak wood as rocker
- Five 3/4 x 2 1/2 x 19 1/2 inches teak wood as bottom slats
- Dowels
- Wood glue or clamps
- Bevel
- Sandpaper
- Hack saw or band saw
- Wood shaper
- Paint brush
- Wood varnish or paint
- Measuring instrument
Having a teak rocking chair in your patio or any part of your house would really provide you a great and peaceful avenue to relax. With all its beauty, teak is the best wood for a rocking chair. Its sturdiness would certainly be a guarantee that your rocking chair will last generations after generations. Can’t wait to build your own teak rocking chair? Follow the simple steps below:
Step 1 – Get a Plan
Download free rocking chair plan from the Internet or you can make one of your own. This way, you will be able to assess the sizes of the wood you will be using.
Step 2 – Cut the Wood
Cut teak wood according to the sizes indicated in your rocking chair plan. If you need help in this, you can ask the home depot where you have purchased the wood to cut them in the sizes you need.
Step 3 – Assemble the Posts
Square one end of each of the front posts. Remember that they should have the same length. The back posts, on the other hand, should be thicker. Grind a flat surface on the top and bottom corners of the posts. Consider making beveled edges.
Step 4 – Fasten the Other Wood Parts
Attach the different wood parts according to the plan that you have. You might want to consider using clamps in this regard. Use dowels and wood glue to fasten the wooden arms to the posts. For the back part of the rocking chair, you might need to bed wood according to the size required. Just remember that every surface curve must at least have a 22 inches radius.
Step 5 – Cut Mortises and Tenons
Check out for any mortises and tenons in the posts and rails. You should also see if the front width of the chair is bigger than its back width. There should at least be a two-inch disparity. Cut and lay off the tenons using a bevel.
Step 6 – Assemble the Bottom Slats, Side Rails and Other Parts
Fasten the bottom slats to the front and back rails of your rocking chair. If it is needed, create a ¾ inch groove to make them fit. Check the back and front parts for anything that needs extra fastening. If you choose to use wood glue, make sure they are completely dried before you assemble the side rails and arms.
Step 6 – Sand and Paint the Rocking Chair
Sand all parts of the rocking chair to take away rough surfaces. Apply paint, teak oil or varnish as desired.
