Login Error
Close
How to Build a Tiled Walk-In Shower Part 3
by DoItYourself Staff
what you'll need
  • Shower fixtures
  • 2 Channellock pliers
  • Plumbers tape
  • Philips screwdriver
  • Flat head screwdriver
  • Allen Wrench
  • Cloth
  • Caulking
In the third and final part of the series on how to build a tiled walk in shower, we will focus on the plumbing and the finishing aspects of this project. (To return to Part 2, click here.) Now that you’ve designed and tiled your bathroom walls, all that’s left for you to do is to connect the plumbing and the bathroom fixtures. Now that the end is near, think of the wonderful shower experience that awaits you and let’s get going!
Step 1 – Turn off the Main Water Supply
Although this is up to you, most people feel comfortable turning off the main water pipes before starting this job.
Step 2 – Attaching the Shower Arm
Wrap plumbers tape all around the new shower arm fixture. After this, put the new shower flange plate over the shower arm. Screw the shower arm clockwise into the shower wall by using the channellock pliers with a rag in its jaws so that you do not scratch the new shower arm. You will need to insert the channellock pliers into the end of the shower arm in order to finish tightening it so that the shower arm is downward pointing.
Step 3 – Attaching the Shower Head
Make sure that there is plumbers tape around the end of the shower arm facing you. If there is not enough, add some on. After this, you will need to tighten the newly purchased shower head clockwise onto the shower arm by using your channellock pliers. You will also need another pair of channellock pliers to hold the shower arm steady whilst fitting in the new shower head.
Step 4 – The Face Plate
Place the face plate onto the cut hole that is in your shower before screwing it into place with either a flat head or Phillips screwdriver.
Step 5 – Fitting in the Shower Knobs
In this step, you will need to fit in all of the shower knobs, including the hot and cold water taps. Use your Phillips screwdriver to install the knobs with the flanges. After this, you will need to use your flat head screwdriver to put the plastic pieces into the shower knobs.
Step 6 - Caulking
After doing all of this work, the worst thing that could happen is for everything to leak. As a result, you will need to use caulking all around the shower face plate. Caulk is a waterproof sealant which will prevent water from going in and damaging all of the work that you have just completed.
Step 7 – Testing
Turn the water main back on, if they are not already on. Test the hot and cold water taps to ensure that it is working in perfect condition. You will need to check for any leaks. If any leaks are found, use caulking or moisture resistant drywall. If everything is fine, celebrate and enjoy your brand new shower.
project steps
 forum activity
