Login Error
Close
How to Build a Wooden Window Cornice
by DoItYourself Staff
what you'll need
  • 1/4 inch faced plywood
  • L brackets
  • 13 or 14 for cleats
  • 2 1/4 inch dry wall screws
  • Measuring Tape
  • Paper
  • Pencil
  • Carpenters Square
  • Jig Saw
  • Gloves
  • Dust Mask
  • Safety Goggles
  • Sander
  • Glue
  • Hammer
  • 3/4 inch Wood Screws
  • Screwdriver
  • Drill Bits
  • Drilling Machine
A wooden window cornice adds beauty to any room. You can add a wooden window cornice to your home and change its look instantly. Learning how to build a wooden window cornice is not difficult. It is a great advantage if you can build it yourself instead of hiring professionals to do it. By following this step by step guide you can easily build your own beautiful window cornice.
Step 1 – Measurements
Measure the width of the window for which you want to make the cornice. Measure the exact width of the window and the length from the top of the window. You can decide how much you want to cover the top of the window. Add 2 inches to the width of the window on both sides.
Step 2 – Design it on Paper
Make a design of the pattern of the cornice on paper and put it up against the window to get an idea if the design is good or not.
Step 3 – Cut the Wood
Trace the pattern out on the wood. Use the carpenter’s square to mark the height and width of the cornice. Use the jig saw to cut the wood, use all safety precautions while using the jig saw.  Sand the edges to get a smooth finish.
Step 4 – Panels
Make sure the side panels are the same height as the face of the cornice. Mark the measurements on the ¼ inch plywood board with a carpenter’s square and cut it with the jigsaw.
Step 5 – Cleats on the Panels
Use the 1×3 or 1×4 wood and cut four 2×2 inch cleats.
Step 6 – Cleats
Take 2 of the cleats and apply glue to its face and fix it ½ inch from the top and ¼ inch from the side of the cornice. Take two ¾ inch wood screws and drive it into the cornice and the cleats to secure it properly.
Step 7 – The Other Two Cleats
Apply glue to the other two cleats and fix it on the back of each panel, ½ inch below the top edge of the panel and secure it with two ¾ inch wood screws.
Step 8 – Position the Panels and Cornice
Position the panel to the cornice properly. Make sure you lay it on an even surface before fixing it together.
Step 9 – Attaching the Cornice and the Panels
Attach the cornice and the side panels together by placing the end of the panel upright with the cornice edge. Take two ¾ screws and fix the side panel to the cleat that is on the cornice. Use a drilling machine to make the holes through the panel to the cleat on the cornice.
Step 10 – The Other Side
Follow the same method of fixing the panel to the cornice for the other side of your window cornice.
Step 11 – Sand the Edges
Sand the edges of the cornice to obtain a clean smooth finish.
Step 12 – Adding Fabric and Fixing it to the Wall
Now you can hang fabric on your cornice and fix it to the wall.
 forum activity
