How To Build Deck Stairs
Although building deck stairs sounds like a complicated and time consuming endeavor, when properly planned it can be quite simple and a relatively fast task. Deck stairs are essential for many different designs, especially if the deck is placed above ground level as most are. However, it is important for someone considering building their own deck stairs to become familiar with the zoning laws of the neighborhood in which you live in. This prevents any nasty surprises arising from a lack of awareness about the proper regulations. Always check to see if any building permits are needed, and make sure your design will fit in with zoning codes in your local area. This article will simplify the construction process of deck stairs by breaking down each action into easy to follow steps.
Step One
The first step you must take in order to build your deck stairs is to measure for the rise and run of the stair case. This is done by measuring the distance between the deck and the ground (this is often referred to as the vertical drop or measurement). After obtaining this distance, divide the number by 7. The answer that you get will be the number of steps required for the stair case.
Next, make sure to mark on the deck where the two stringers for the stairs will be placed. They should be about thirty-six inches apart from each other.
Step Two
Once your stringers are marked and the vertical drop is measured, it is time to decide on the run needed for the stair case. The chosen run is than multiplied by the number of steps in the stair case. The number that is obtained from this is called the span.
Step Three
Now that the measurements and calculations are completed, the deck stair posts have to go in. Simply drill holes about two to three inches away from the stringers. Fill these holes with concrete after properly fastening the post.
Step Four
The next step of the project is to cut out of the stringers using a circular saw for the majority of the cuts, and a hand saw for the parts the circular saw can’t get to. Remember to leave about one inch when you are cutting your stringers so they stairs can hang off a little bit and attach the stringers to the deck.
Step Five
Finally, cut the boards you will use for the stairs (taking into account the one inch overhand) and fasten then in place by using nails and screws. Typically, it is easier to use two thinner boards per step when constructing the stair case. In addition, a tiny space should be left between each of the boards.
Step Six
Finish off the steps my painting or staining the stairs to match your deck. This isn’t necessary but it will make the stairs look more natural compared to the deck. You will also want to sand off any rough edges.
You are officially done building your own deck stairs!
