How to Build Door Headers
what you'll need
- Tape measure
- Framing square
- Circular saw
- Hammer
- 2x8 framing lumber
- 1/2 -inch CDX plywood
- 16d sinker or box of nails
If you are looking to save money on getting door headers, you can use materials that you may already have on hand and do it yourself instead of hiring someone to do it for you. You need to keep in mind that structural support is very important and the framed wall you are working with needs to be durable. The size of the door headers you want to make will determine the size and type of materials you will need. The following will give you the general idea.
Step 1 – Measurements
The first thing that you want to do is measure the width of the door’s rough opening. Use a measuring tape and pencil marker for the same.
Step 2 – Markers
Your next step is going to be to mark three lengths of 2x8 framing lumber. The dimensions need to be determined by the measurements in step 1. All you need to do now is add 3 more inches to the earlier dimensions. You will then use a framing square and extend your mark across the face of the board pieces.
Step 3 - Boards
You will next need three lengths of 2x8 cut and marked as in step 2 and you can use a circular saw in order to do this.
Step 4 - Matching
Next you are going to lay out two pieces of the plywood, ½ inch and 7 ¼ inches wide by the length of the three pieces that are cut 2x8 as in step 3.
Step 5 - Continue
Taking the plywood pieces in step 4, you will cut these out again using the circular saw.
Step 6 – Final Step
The last step is to take the 2x8 pieces along with the plywood and lay them out in alternating layers. You need to do this on a flat surface and keep the ends and the edges flush. Using the 16d nails, you will then attach the pieces together through the already assembled pieces. These should be 6 to 8 inches apart as needed. You will then flip the header over and repeat this step over and over until the assembly is complete.
Extra Tip
This is one of the easiest ways to be able to accomplish your task without spending a lot of money on unnecessary materials. It is also a great way to be able to get the project done on your own so that you will not need to spend a lot of money on someone else to do the project for you. Not only are you going to be able to keep your money in your pocket but you will be able to do this over and over again when the need arises. This means you will no longer have to worry about finding someone to come out and do the project for you. All you will need to get is a few pieces of board and some nails to do the project yourself.
