Login Error
Close
How To Build Garage Cabinets
by DoItYourself Staff
How to build garage cabinets is actually a lot easier than you may think. There are some great do it yourself kits that you can purchase that make building the cabinets and installing them a breeze. But if you decide not to buy a kit, preferring to use blueprints and buying the material yourself. As long as you follow the plans and a few easy rules, you will have your cabinets built correctly and in no time.
Measure Everything
When learning how to build garage cabinets, measurements are the key. Follow the cabinet plans and make sure that all of your measurements are correct. Even being out a 1/4 an inch can ruin the cabinets. Don't be afraid to take the time to measure everything twice, just to be on the safe side.
Buy the Proper Materials
If your plans call for 6 inch wood, then go with 6 inch wood. Remember that you will most likely be storing heavy things in your cabinets, so you want to make sure you go with the recommended materials. There is no sense in taking the time to build a high quality cabinet with sub par materials.
Get the Right Tools for the Job
Ever try to screw in a screw with the wrong screwdriver? Make sure that you have all of the tools that you will need throughout the project. There may be very different methods when it comes to how to build garage cabinets, but having the proper tools is a necessity.
Learning how to build garage cabinets can not only be rewarding, but will also insure that you are getting exactly what you need.
 forum activity
