Login Error
Close
How to Build Wooden Utility Shelves
by DoItYourself Staff
what you'll need
  • Pencil
  • Ruler
  • Wood putty
  • Four 2 inch finishing nails
  • Polyurethane finish or clear water base
  • Fine sandpaper
  • Hammer
  • Paintbrush
  • 2 loop hangers
  • Saw
  • Two screws or nails for the wall
  • Acrylic and prime paint for a clear and solid color finish
Utility shelves have lots of uses. Basically, they will save space in any room. You can build or buy shelves in metal, plastic or wood. Here are the steps on how to build wooden utility shelves.
Step 1 – Prepare the Shelving Pieces
Purchase a piece of wood that is 25 inches long, six inches wide, and two inches thick. Use a ruler and pencil to mark 20 by 5 inches off for the shelf. There will be 5 by 1 inch left over smaller wood from the shelf. Cut this smaller wood into two for the brackets. Draw a one-inch, 45 degree angle diagonal line on each end of the smaller pieces. Start the line from one corner towards its adjacent side. Make sure that the two diagonal lines are running the opposite direction. Saw the diagonal line. Make the wood pieces smoother by sanding them out.
Step 2 – Prepare Installation of the Shelf and Brackets
Mark the bottom and top part of the shelf. There must be two inches from each end. Hammer 2 nails on the marked spots until their tips appear underneath. Glue the brackets on the shelf’s underside. Let the glue dry thoroughly. Continue to hammer the nails until they are buried enough to connect the wooden parts.
Step 3 – Install the Shelf
Attach a hanger for the brackets. Find wall studs for attaching the hanger. The studs must be approximately 16 inches apart. Use nails in hanging the shelf. Utilize a carpenter’s level to ensure that one side of the shelf is leveled when hanged. Use a small sized plain rubber ball if you don’t have a carpenter’s level. Mark the shelf’s other side if the rolling of the ball stops or if its liquid stops moving. Position a nail and finish hanging the shelf. Hammer the nails on each end of the brackets to secure the shelf. Apply wooden glue on the shelf wood to secure it on the wall. Wait until the glue is dry enough.
Step 4 – Paint the Shelf
Apply a coat of white primer on the installed shelf. Let it dry thoroughly. Brush 2 or more paint coats. Ensure that the previous coat is completely dry before applying another coat. Follow the directions of the paint manufacturer in applying a clear finish over the paint.
Step 5 – Decorate the Finished Shelf
Decorate it with a fabric piece. It must be 6 inches wide and 32 inches long. Use a 6 inch gingham piece. Fold down the top part by one-inch before hemming, and then fold up the bottom part by 1 inch before hemming. Glue the finished material piece into the shelf’s outer edges.
 forum activity
