Login Error
Close
How to Burp a Vehicle's Coolant System
by DoItYourself Staff
The coolant system on any vehicle, even when the vehicle’s radiator appears to be full, may not adequately cool the vehicle’s engine. Sometimes this is because the radiator is plugged. Other times it is because an air bubble in the car’s cooling system has developed and is keeping the coolant from getting to the car’s engine. In situations where your radiator is working normally, “burping” the cooling system may be the only way to get the coolant to do its job. Here are three steps that will help you “burp” your car’s coolant system.
Step 1 – Fill your Car's Radiator
Mix new coolant with water and add this mixture to the radiator and overflow reservoir until they are both full.
Step 2 – Let the Car Engine Run
With the radiator cap off, start your car and let it run. As it heats up, watch the temperature gauge to be sure the engine doesn’t overheat. After a few minutes the coolant level will fall, an indication that the trapped air has vacated the car’s cooling system.
Step 3 – Finish
Pour more coolant into the radiator until it is full again. Then replace the radiator cap and turn off your car’s engine.
 forum activity
