Login Error
Close
How To Calculate Area For Siding
by DoItYourself Staff
If you are planning to install new siding on your home, you must know the square footage of your home in order to calculate how much siding you will need. This is a relatively easy task and involves some basic geometry calculations.
Step 1 – Draw a Diagram
First, draw a diagram of your house. Break the building structure down into basic geometrical shapes—rectangle, triangle, square, etc. Make a diagram for each side of your house and for any outbuildings onto which you will install siding.
Step 2 – Measure the Building
Now, you will need to measure the length and width of each side of your house. Include each geometrical shape that your diagram includes.
Step 3 – Begin Calculating for Area
  • Rectangles – You can find the area of a rectangular area by multiplying the width and length together.
  • Square – Find the area of a square by multiplying the width and length together.
  • Triangle – Add the lengths of the 3 sides together, and divide the total by 2 to find Area. Now multiply the following:
 Area x (Area – Side 1) x (Area – Side 2) x (Area – Side 3)
  • Now find the square root of this number using a calculator. This is the area of the triangle.
Add the areas for all of your geometrical shapes together and you will have the area for the entire building.
Siding Waste
With almost any kind of siding installation, there will be waste caused by matching seams, cutting for doors or windows or simple unfamiliarity with the type of siding. To accommodate the waste, once you have your calculations for the building area, add a minimum of 10 percent.
When you order or purchase siding, make sure you understand the supplier’s policy about returning any materials that you do not use. While it is often helpful to keep a small amount of extra siding available for repairs or damage in the future, if you have a great deal of excess left over from installation, you may be able to return it for a refund.
Ordering Siding
Remember that you will not only need to order the siding that will go on your building. You must also order fascia, house wrap and any supporting materials that your specific type of siding requires for installation.
Even if you plan to work with an installer, it is a good idea to do your own calculations to know how much siding you will need. Having this knowledge will help you evaluate the installer’s knowledge and understanding of your project.
 forum activity
