Login Error
Close
How to Calibrate a Digital Meat Thermometer
by DoItYourself Staff
what you'll need
  • Glass
  • Ice cubes
  • Water
  • Food thermometer
A digital meat thermometer is one of the tools that several cooks find very helpful since it can show whether the meat is done, and if not, it can give the cook a general idea as to the level of completion reached and how much time should be allowed to have the dish ready. It is also a great help to have a tasty meal rather than a failure. It also acts as a safeguard against food poisoning if the meat is not cooked well enough, since in this case mush of the harmful bacteria would not have been destroyed.
Step 1 - Fill a Glass with Ice and Water
One popular method which is used to calibrate a meat thermometer is to fill a glass with some ice at the bottom, and then top it up with some hot or boiling water. Leave it for a few moments to give some time for the water to chill, but do not allow too much time for the ice to start to melt.
Step 2 - Insert the Thermometer in the Water
At this point insert the thermometer in the glass, and allow its tip to touch the ice. This is an easy way to calibrate it as it should register in the range of about 32 degrees Fahrenheit. If this temperature is not recorded then the thermometer is not accurate. Being a digital thermometer you do not have the possibility to adjust accordingly by fixing the adjustment wrench. So, in such a case you might have to replace it.
Step 3 - Sterilize the Thermometer
Considering that the thermometer recorded the desired temperature of 32 degrees Fahrenheit you can then sterilize it by washing it with some warm water before using it in the food.
Step 4 - Test the Food’s Temperature
Afterward, you can use the thermometer to check the cooking meat’s temperature by making sure to insert its tip in the thickest part of the rib, fillet or whatever type of meat you are cooking. It should provide a good and credible result after you have calibrated it by using this simple method.
Step 5 - Repeat
It is important to repeat this calibration process on a regular basis since it is a very common occurrence with most thermometers to lose some of their accuracy. After all it is a very simple method which takes just a few minutes time, and it allows you to put your mind at rest that your thermometer is really recording the accurate temperature when inserted in the meat you cook.
The calibration process can also be carried out by a professional or the manufacturer of the thermometer itself, in order to ensure that the readings are as accurate as can be. In fact in the case of digital thermometers it is recommended to carry out the calibration process more frequently due to the fact that they cannot be adjusted easily as in the case of thermometers which include a mini wrench and the possibility to make manual adjustments easily.
 forum activity
