Login Error
Close
How to Calibrate a Digital Weight Scale Without Weights
by DoItYourself Staff
A digital weight scale performs best when calibrated regularly. New scales have default weight settings however these are not a guarantee for calculating weight accurately. As digital scales are touted for their ease of use and dependability, the calibration must be correct or the accuracy of the scale will be affected.
Digital scales come in a variety of sizes and weight capacities. Some models also have printers for a written record of the weight measured while others can record the measurements electronically through your computer. This reporting of weights is to have a written record of the weights measured over a time period. For dieters this reporting is beneficial as they will have records that will track their weight loss effort.
Calibration Method
By following a few steps, you can easily calibrate a digital weight scale without using weights. You will need:
  • Scale owner’s manual
  • Household items that have known weights
  • Flat, level surface
Step 1 – Determine the Weight Capacity
Digital scales have a standardized weight capacity which is dependent on the size and durability of the scale. This weight specification is the highest weight that can be measured by the scale. It's listed in the scale’s owner’s manual or you can also find this information listed directly on a tag on the scale or on the manufacturer’s website.
Step 2 – Find Substitute Weights
Locate household items to use as substitute weights that have known weights. Bags of flour or sugar work well as they come in set weights (5 or 10 lb. bags). The weight of your item must match the maximum weight capacity of your scale to calibrate it properly.
Step 3 – Activate the Scale
Set the scale on a flat, level surface. Activate the scale and wait a few moments for the scale to stabilize the readings. Make sure that the weighing surface is empty during stabilization. Choose the calibration button or mode setting on the scale.
Step 4 – Place the Substitute Weight
Place your substitute weight on the scale’s weighing surface in the center. Wait while the scale calculates the total weight.
Step 5 – Calibrate the Scale
To calibrate the scale, choose the calibration button or mode setting. This will trigger the scale to register that the weight of the substitute weight is its maximum weight capacity and make adjustments accordingly. This process is complete when the display shows all zeros or “End” is listed on the display.
Step 6 – Double Check the Calibration
To check if the calibration process worked properly, start with removing your substitute weight from the scale’s weighing surface. Turn the scale off and wait about 60 seconds. Turn it back on and choose another item with a known weight such as a bag of powdered sugar (2 lbs.). Place the item on the weighing surface and wait for the reading. If the scale reads 2 lbs., the calibration was a success.
 forum activity
