Login Error
Close
How to Care for a Honed Granite Countertop
by DoItYourself Staff
what you'll need
  • Soft cloths
  • Warm water
  • Plastic putty knife
  • Natural stone cleanser
  • Soft-bristled brush
  • Baking soda
  • Bowl
  • Wooden stick
  • Plastic wrap
  • Masking tape
  • Natural stone penetrating sealer
  • Soft cloth
A honed granite countertop is a popular choice for home kitchens. This is partly due to its natural beauty and high durability, when properly maintained. Unlike polished granite which has an attractive shine, honed granite has a soft, matte-like appearance. This is because the stone isn’t polished to the same extent as the polished variety. It isn’t difficult to maintain a honed granite counter. However, it easily develops stains if proper care isn’t given. Some guidelines on maintenance are given below to help keep your countertop in good shape longer.
Step 1 – Daily Cleaning
Wipe your countertop daily with a soft, damp cloth to remove dirt and loose materials. This is especially recommended after you’re done with preparation of meals. For food that has dried on the countertop, use a spoon to carefully scrape it away, then wipe with a damp cloth. Granite is an extremely hard stone and doesn’t scratch easily. Wipe the counter with a soft cloth to absorb moisture and prevent water spots.
Step 2 – Weekly Wash
Once a week, you may want to wash your countertop with water and soap. It is best to use a natural stone cleanser. Make use of a soft-bristled brush to clear away stubborn dirt. Rinse the counter with warm water then wipe dry.
Step 3 – Stain Removal
A poultice comes in handy when you have to clear stains from granite. While various poultices are commercially available, you may want to make one yourself. Place ½ a cup of baking soda in a bowl. Add enough warm water to create a thick paste. Mix the contents with a wooden stick until you have a thick paste. Spread the paste onto the stain and cover with a plastic wrap. Secure the wrap with masking tape. Allow the poultice to draw the stain out overnight. Remove the poultice with a plastic putty knife. Rinse the counter with warm water and wipe dry. Use a damp cloth to wipe acidic spills as soon as they occur. This helps to prevent infiltration of the liquid into the granite which causes stains.
Step 4 – Seal Periodically
Obtain a natural stone sealer that is suitable for granite from a home improvement store. Use a soft cloth to apply the sealer onto the countertop with long, smooth strokes. To facilitate proper absorption, it is best to spread a light coat of sealant. Allow sufficient time for the countertop to dry, then apply a second coat. Due to the high porosity of honed granite, it is best to apply a sealer every 6 months. This helps to guard against stains. It also extends the longevity of your countertop.
Step 5 – Cleaners to Avoid
Although granite is extremely hard and doesn’t scratch easily, be careful to avoid abrasive cleaners. Steel wool and stiff-bristled brushes aren’t a good idea. With frequent use, these can leave your countertop with a scuffed appearance. Acidic cleaners, bleaches and alkalis can cause your granite to etch. This shortens its durability.
 forum activity
