Login Error
Close
How to Care for Engineered Hardwood Flooring
by DoItYourself Staff
what you'll need
  • Broom
  • Vacuum cleaner
  • Plastic furniture guides
  • Throw rugs
Engineered hardwood flooring is composed of a core of solid hardwood, and covered with a thin layer of finished hardwood veneer. Engineered hardwood is completely made of genuine hardwood. It offers all the benefits and attractiveness of hardwood flooring, along with added durability and strength. To prevent damage to this costly investment, you must take some steps for regular care and maintenance.
Step 1 - Clean Regularly
Use a soft broom to clean your engineered hardwood floor daily. Dust, dirt and grime can rub on the surface of the veneer and cause scratches and dents. This will also reduce the luster of the veneer. After cleaning with a broom, it is preferable to follow up with a vacuum cleaner, to get rid of all the minuscule particles. Clean all the corners and under furniture thoroughly.
Step 2 - Keep Floors Dry
Never let water accumulate on engineered hardwood floors. Protect the floor as required, especially if you have a water filter or indoor plants. Never mop wood floors with a wet mop. If it takes time to dry, the floor will absorb the moisture, and swell over time. Before mopping, squeeze out maximum moisture from the mop and then clean the floor. Take care of food spills and drops right away.
Step 3 - Use Recommended Cleaners
Never use general floor cleaners on engineered hardwood flooring. This can cause serious, permanent damage and spoil the look of the veneer finish. Because the veneer cover is so thin, it must be treated with utmost care to avoid wear and tear.
Step 4 - Place Throw Rugs or Mats near Entry Points
To avoid tracking in dirt and grime from outside, place throws or doormats near all doors. It is also vital to vacuum the throws on a daily basis to avoid transferring grime from these items onto the floor.
Step 5 - Never Walk around with Outdoor Footwear On
Always leave outdoor footwear near the door as soon as you walk in. Never wear sharp heels on engineered hardwood, as they can chip or scratch the surface badly. Only use indoor footwear with soft soles, and clean them regularly.
Step 6 - Protect Floor from Furniture
Use protective items such as plastic glides on the legs of furniture to protect the floor from accidental damage. It is always possible that the furniture may be moved around accidentally, scratching the floor in the process.
Step 7 - Use Rugs near Sinks
It is not a good idea to use wood floors in the kitchen. However, if you do have engineered hardwood in the kitchen, you can preserve its longevity by protecting it appropriately. Use a rug or throw in front of the kitchen sink to protect the floor from water splashes.
Step 8 - Use Caution when Moving Heavy Items Around
You must be very careful when moving around heavy items such as furniture or appliances. Remember that engineered hardwood can only be sanded up to 3 times because the finishing layer is so thin. It is therefore important to avoid damage. Before moving any heavy items, place a thick cloth or a milk carton under it, so that there is no friction or direct contact with the floor.
 forum activity
