How to Care for Teak Wood Patio Furniture
Many of the finer homes and business places feature teak wood patio furniture. Teak comes from the natural rain forest. Thus, it is resistant against rot, insects, and various outdoor elements. Teak is also a very beautiful wood for furniture. Hence, it is a little more expensive than other types of wood, such as cedar or oak. In order for teak wood to remain splendid, you need to learn how to take care of it properly, especially if teak is used for outdoor furniture.
Sanding Teak Wood
With time, outdoor teak furniture will lose its golden honey look, and if not treated properly, it will continue to change color until it will reaches a very dark gray. In order to prevent the latter from happening, you will need to sand the teak furniture regularly with a soft fine sandpaper. Sanding is the most effective way to cleans you outdoor teak furniture.
Teak Oil
Another method to maintain that natural golden color of teak is to use teak oil. Teak oil is a special type of oil specifically designed for outdoor teak furniture because if you use it on indoor teak, it may cause the furniture to blacken. Teak furniture can blacken rapidly if you have mildew present, so keep a look out and check regularly for mildew. Teak oil doesn’t substitute sanding, but it can be applied between sanding to keep the golden color. Remember, teak oil doesn’t extend the life of teak but simply brings out that original golden honey color.
Precautions To Protect Teak Wood
Winter is public the number one enemy of teak furniture, and thus, you have to take some precautions to maintain your teak furniture and keep it as beautiful as possible. Firstly, never leave your outdoor teak furniture out in a puddle of water because that will create a lot of moist and bring the teak a lot of serious damage. The best solution is to transfer your outside teak furniture indoors for winter, but alternatively, you can leave them outside as long as you provide adequate cover from weather elements.
Staining Teak Wood
Another option is staining. This must be used as a last resort since a lot of teak furniture manufacturers discourage the staining of teak furniture because it ruins that natural golden color, which is a main feature of teak. Once you have stained the wood, you have to regularly rinse it with stain preservatives because if not, over time, the teak will start to peel due to the oil. Normally, staining is an irreversible act, although it can be made reversible with a lot of sanding, but it will never bring about that original golden color of teak, so use this method as your very last resort.
Teak is a very beautiful piece of wood, but for it to remain as such, you have to periodically take care of it, and then you can be certain that you can enjoy your teak wood patio furniture for a very long time.
