How to Change a Washer on a Shower Faucet
what you'll need
- Penetrating Oil
- Pliers
- Wrench Set
- Screwdriver
- Plumber's Putty
- New Washer
If you notice that water is constantly leaking from your shower, it might be time to change the shower washer. The washer in your shower faucet might get worn or damaged due to normal wear and tear, so you should replace it as soon as possible. Instead of calling a plumber to do the job and paying him, you can do the job yourself and save some money. With the right set of tools and spares, including this guide, you will be able to change the washer on your shower faucet.
Step 1: Shut off the Water Supply
Shut off the water supply to the shower faucet. If you don't have an individual shut off valve for the shower faucet, you will have to shut off the main supply to your home.
Step 2: Drain the Water
Open the faucet to drain out any remaining water that may be still in the shower.
Step 3: Remove the Handle
Remove the handle from the stem of the faucet.
Step 4: Remove the Nut
You can use a bit of penetrating oil to loosen the nut, and then use the pliers to completely remove the nut from the escutcheon.
Step 5: Remove the Screws and Washer
Use the screwdriver and remove the screws on the faucet stem. Once the screws are out, you will be able to remove the shower washer. Remove the washer and keep it aside.
Step 6: Buy a New Shower Washer
Buy a new washer for your shower. You can take the washer to the local hardware store and get a replacement. Make sure the new washer is the same size as the one you just removed from the shower faucet.
Step 7: Replace the Washer
Replace the washer by putting the new washer in its place.
Step 8: Replace the Screws
Replace the screws on the faucet stem one by one. Use the screwdriver to tighten the screws.
Step 9: Plumber's Putty
Use the plumber's putty at the bottom of the escutcheon. You need to use just a small amount, not too much.
Step 10: Reconnect the Faucet Stem
Reconnect the faucet stem and handle and reinstall the faucet.
Step 11: Open the Water Valve
Now you can open the water valve for the faucet or the main supply valve, whichever you turned off. Open the shower faucet and check the shower; it should be working fine now.
That's all you need to do to change the shower washer. The job is not too difficult, and you can do it yourself. It's not a job that will take up much of your time, and you'll save some money, too.
