Login Error
Close
How to Check a House for Water Damage
by DoItYourself Staff
what you'll need
  • Flashlight
Whether you’re buying a home, or selling a home, it’s important to know how to recognize the signs of water damage. Water can not only damage walls, floors and cause toxic mold to grow; it can even cause permanent structural damage to a home. Water damage can be caused by leaks, floods, overflowing water sources, ice dams, accumulation of water in the basement, or leaky appliances. Although water damage can exist anywhere inside a home, there are some important high risk areas to check first.
Step 1 - Walls
The easiest sign of water damage to spot is water stains on the walls and/or ceilings. Also check around the window and door frames for stains. Any unusual stains should be taken seriously, as they could be a sign of a leaky pipe or drain inside the wall. Also look for cracks in the drywall. An area of wall that has been exposed to water can also have a swollen appearance and be soft to the touch.
Step 2 - Floors
Water damage can happen to any type of flooring and can also seep down to the sub floor. Look for any warping or buckling of the floors, especially in the basement. If the floor looks warped, water damage is most likely the cause. Also be wary of white or dark stains on wood floors, damp carpeting, or a general smell of dampness or mold.
Step 3 - Pipes
Inspect the piping in the kitchen, bathrooms, laundry room and basement to check for corrosion around pipe connections, leaks or water stains. Inspect the caulking around the bathroom fixtures. Missing or loose caulking could be from water seepage. Look for missing grout or signs of mold. Check the water heater for wet spots on the floor or rust on the tank.
Step 4 - Basement
Basement leakage is a common problem found in houses. Water in the basement often causes damage to the flooring, baseboards, walls and furniture. In addition, odors caused by mold and mildew can be unpleasant and even cause health problems. Look out for cracks, stains, rust, dampness, mold and odors.
Step 5 - Attic
Check the attic for stains, mold, and other signs of leaks, especially the valleys where 2 roof planes come together, the flashing where the roof meets the walls and the flashing around roof vents and chimneys. The insulation should be dry and in good condition. Houses located in cold climates can develop ice dams on the roof, which cause water to leak into the attic from melting snow and ice on the roof.
Step 6 - Exterior
Make sure to check the exterior of the house as well. Check the roof for damaged flashing and missing, cracked or curled shingles. If you see standing water anywhere outside the home, it could be the sign of a problem. A puddle could be due to poor drainage in the yard, leaky rain gutters or gutter spouts that don’t take water far enough from the house. The house should be situated on the highest point of the property, with the ground sloping away from the house.
 forum activity
